Dimming Lights
Old Mar 25, 2011 | 01:51 PM
WannaScoopaDis's Avatar
that all makes me feel better then lol
Old Mar 25, 2011 | 06:44 PM
drtom's Avatar
Banned
so, curious as usual when something dont ring true,i took a digital meter with me on a shopping trip,20 miles out,20 back.
i figgered if the lites were gonna dim at every stop i should see it dip on my meter.
i must have stopped a hunnert times, normal traffic and strings of stops in mt parking lots....r u ready?
i saw readings from 15.09 to 15.14. about 50 millivolts with fluctuations of +- 20 mv routine as i drove steady. its daylite so i naturally cant see but i had the lites on and off. no difference. i figger it wood take a few volts to notice a dimming. no luck. man i stopped normal,,i banged the brake, i tried everything. a few times i saw a split second dip of a volt, but rare.
so tonite ill throw away another 5 or 10 bucks and cruise around banging the pedal,ill watch the lites AND the meter and report back later,,,
meantime,ifn u got lites dimming id look at the volts right at the batt + to start
Old Mar 25, 2011 | 09:44 PM
krlemoine's Avatar
my 08 does the same thing...
Old Mar 25, 2011 | 10:46 PM
drtom's Avatar
Banned
just got back,wow its cold,25 algore degrees! i drove 10-12 miles in the country where i can stop anywhere/often. i cannot duplicate what you guys are saying.
there is no noticeable dimming and i am also seeing a max of .1 volt change,maybe .15.
the tach also never goes below 600 and actually stays at apx 700 till i LIFT my foot off the brake!
so im seeing tight control of rpm and volts,hi beam,lo beam,,moonbeam!
sometime back someone talked of rpm drop at stop and i wondered if that would cause a dimming.
but actually the batt is there to absorb bumps in demand,,,and what change is there in demand when u stop?? naturally the generator slows down but the batt should hold it.
btw the ONLY dip i see,down to 9+volts is at crank time,a few seconds and thats over 100 amps. that u expect
so im doing live tests,cannot see any dip,no dim.
do i have the worlds best hummer?
smooth idle, check
brite lites,check
stable rpm,check
no leaks,check
no rattles,yet,check!
guess i better lock it up and get a guard dog huh!
Old Mar 26, 2011 | 12:19 AM
Draketh's Avatar
If you check out the thread where the guy is having problems with his stereo cutting out I talk about how I upgraded my electrical system under the hood. Until I did that I could dim my damn lights by rolling my window's up and down!
Old Mar 26, 2011 | 12:26 AM
drtom's Avatar
Banned
yeah ,without lookin im guessin its connections!,gotta be
Old Mar 26, 2011 | 04:20 PM
The big 3??
Blake0496
Dec 19, 2012 06:15 PM
J.Carroll
Oct 31, 2012 11:16 AM
Fallz
Nov 27, 2006 04:03 AM
bigwood212
Jul 11, 2006 01:31 AM
CruisinCarAudio
May 25, 2006 04:14 AM
