Difficult to install a Brush Guard?
How difficult is it to install a factory brush guard? Seems like it bolts to the tow hook area... does is use the same bolts etc... any instructions anywhere?
You answered your own question
Almost! But... do you take out the 2 tow hook bolts on each side and reuse them... do they bolt into the frame or are there nuts underneath where I'll need to pull the skid plate and get at.... etc...
i have a 06 and all u need to do is take the bolt out that holds the recovery loop on and then there are 2 bolts that connect to the h3 and all u have to do is loosen enough till there is room to set the guard in place and then re tighten those bolts and then put the recovery loop back and slide the bolt through and tighten and your done. its so easy that my 2 year old daughter can do it if she had the strength
also a tip, the factory did a good job tightening some of those bolts, so they take a little elbow grease to get off
