Did I Get a Good Deal
Old Nov 20, 2017 | 12:28 PM
flahiker49's Avatar
Default Did I Get a Good Deal
Well, I had the dreaded front end oil leak so I took it to a local repair shop which indicated they worked on Hummers. Out the door I paid $830.67 which included:
Crankshaft oil seal
Harmonic Balancer
Serpentine belt
Oil change
And on the Crankshaft seal it say: " Remove & replace automatic trans front. w/grill guard - (includes recover, evacuate and recharge air conditioning system."
Includes: R&I Grille Assembly
Includes: R&I Radiator
I do have an external transmission fluid cooler which bypasses the engine cooling system.
Any thoughts?
Old Nov 20, 2017 | 04:26 PM
happythree's Avatar
in winter ,tranny may never get up to top temp, not good?
Old Nov 21, 2017 | 05:53 AM
As long as your transmission cooler has a internal pressure by-pass cold weather should not be an issue. If it does not, then there can be issues.
I would check your model with the manufacturers specs to see if it does.
As far as if you got a good deal it depends on if you are satisfied and there is no more leak. Sounds like a decent deal for the work you had done.
Old Nov 21, 2017 | 06:58 AM
flahiker49's Avatar
Well, since I live in Florida I don't think cold weather is going to be an issue, yes, every once and a while we get down to the 40's but I can always use the SUV. Thanks for the reply's.
Coldblooded
Jan 27, 2016 07:35 PM
Bumble B H2
16
Jun 26, 2007 10:41 AM
SEMO H3
113
Feb 18, 2007 02:12 PM
dilo2001gt
Nov 8, 2006 09:53 PM
RutDogg
Mar 10, 2006 12:57 PM
