Did I Get a Good Deal
Well, I had the dreaded front end oil leak so I took it to a local repair shop which indicated they worked on Hummers. Out the door I paid $830.67 which included:
Crankshaft oil seal Harmonic Balancer Serpentine belt Oil change And on the Crankshaft seal it say: " Remove & replace automatic trans front. w/grill guard - (includes recover, evacuate and recharge air conditioning system." Includes: R&I Grille Assembly Includes: R&I Radiator I do have an external transmission fluid cooler which bypasses the engine cooling system. Any thoughts? Thanks |
external transmission fluid cooler which bypasses the engine cooling |
As long as your transmission cooler has a internal pressure by-pass cold weather should not be an issue. If it does not, then there can be issues.
I would check your model with the manufacturers specs to see if it does. As far as if you got a good deal it depends on if you are satisfied and there is no more leak. Sounds like a decent deal for the work you had done. |
Well, since I live in Florida I don't think cold weather is going to be an issue, yes, every once and a while we get down to the 40's but I can always use the SUV. Thanks for the reply's.
