dead battery
Old Oct 28, 2012 | 06:10 PM
amy11's Avatar
Tainter are you saying check each fuse with meter?
Old Oct 28, 2012 | 07:50 PM
wfturner's Avatar
What is voltage when truck is running ? 14 volts or there abouts ?
If not, that is one problem.
H3's have a circuit cut out feature that turns off accessories when left on, to save the battery
Tainter is right (most of the time [sic]) and there could be a parasitic draw that is taking down an already weak battery. Then you kinda bring it back to life when charging only to have it go bad once truck is turned off
Some help I was . . .
Old Oct 29, 2012 | 06:20 AM
amy11's Avatar
Yeah its charging just above 14 volts.
Old Oct 29, 2012 | 09:50 AM
happythree's Avatar
"So I checked battery seems it it 5.55 millamp draw", Amy said.
5.5 ma is nothing,you must mean 5.5 AMPS or you read it wrong.
5 amps will kill it quickly.
When you read that you can pull one fuse at a time,see if/which one is doing it.
Since many fuses are always connected to 12 volt source,checking voltage won't help much.
Old Oct 31, 2012 | 07:43 PM
amy11's Avatar
No i didnt not mean 5 amps.
Took it to dealer replaced BCM.
Old Nov 1, 2012 | 08:42 AM
wfturner's Avatar
Is that the module that controls the turning off of lights that are left on in the vehicle ?
Old Nov 1, 2012 | 10:36 PM
Happy Hummer's Avatar
Glad its resolved. im confused....lol not hard!
5.55 mil amper is very small. I mean really small draw.
I was under the understanding that the clock ansuch took about 100 mil amper or more.
May be misunderstanding this. An Ammeter is the best sourse for accurate readings
Chris
Old Nov 1, 2012 | 11:04 PM
Ahhh, bad BCM will do it every time. Not a cheap fix and I am glad you checked every fuse before you had to have the BCM replaced. Start with the easy AND cheap(free) stuff that could be wrong and work your way up.
Glad to see it got fixed.
HERHMR
16
Dec 26, 2012 11:11 AM
NIK1
Nov 4, 2008 12:56 PM
doyleh3
Apr 2, 2008 10:01 PM
ralpiefar
Jan 9, 2008 02:22 PM
GameY2J
Sep 4, 2007 09:42 PM
