Cuts out
Old May 11, 2017 | 06:33 PM
Csf2332's Avatar
Default Cuts out
H3 wants to cut out at 60 mph, had new plugs put in,,,still cuts out uphill at 60-65 mph,,,,,any ideas
Old May 11, 2017 | 09:21 PM
norinco3264's Avatar
Probably gonna need more information. Year, trim, miles, and what symptoms present when it cuts out
Old May 12, 2017 | 03:36 AM
Check engine light or any other light "ON"?
Any message on the DIC?
Old May 12, 2017 | 08:08 AM
Csf2332's Avatar
Default Cuts out
The engine light was on. Had it hooked up on machine at garage and they said it was emissions and it was gas cap. They tightened it up and erased the code. Also put new plugs in. My H3 is an 08 sport with 78,000 miles. it only cuts out at about 60-65 mph
Old May 12, 2017 | 08:18 AM
Bunger's Avatar
What brand of plugs did you put in?
Old May 12, 2017 | 08:47 AM
FYI, whenever you have anybody scan the vehicle, write down the actual code(s), do not simply accept their explanation. If it was a loose gas cap, the DIC would display "FUEL CAP", so whatever code they erased for you would be very helpful right now since it probably was NOT for as loose gas cap. There are EVAP codes that may be related to a gas cap leak as a secondary diagnostic to a different problem.
If the CEL comes back on, write down the code(s) & we can help.
Did this problem start after the new plugs were put in?
Meanwhile check your air filter for obstruction (dirt, leaves, crud), if it is just dusty, then that is not involved.
There is no such thing as an H3 "sport". The 2008 choices are:
Base-Cloth/standard radio/Black accents/ 265/75R16(32”)
Adventure-Cloth/Monsoon radio/Black accents/4:1 transfer case/Rear Locker/ 285/75R16(33”)
Lux-Leather/Monsoon
H3X-Leather/Chrome/18" wheels/Monsoon/Square Chrome Brush Guard/ body color hard spare cover/ 265/65R18(32”)
Alpha-Leather/Chrome/Monsoon radio/Cast Iron Front Diff
OffRoad(only on Alpha) 4:1 transfer case/Rear Locker / 285/75R16(33”)
Option Package Combinations:
Base w/Adventure, Lux w/Adventure, Alpha/OffRoad
Old May 12, 2017 | 09:54 AM
Csf2332's Avatar
Default Csf2332
It started before plugs were replaced, H3 sport is what's on the paperwork but it's probably a base. Engine light hasn't been on anymore, and I will write code down if it happens again, thanks
Old May 12, 2017 | 01:59 PM
Start with normal maintenance, replace air filter, maf sensor cleaning, throttle body cleaning.
Do you smell fuel when walking around it?
Cashville
Dec 6, 2013 06:56 AM
bigmoe1315
Feb 8, 2011 09:54 PM
bigmoe1315
Oct 6, 2010 10:03 PM
racegun
Jan 26, 2009 12:44 PM
Ken06H3
Nov 22, 2006 09:38 PM
