CTIS not inflating - Need guidance
Old Mar 9, 2014 | 11:48 AM
Judah0713's Avatar
Exclamation CTIS not inflating - Need guidance
Working on CTIS since it's not inflating. Pump working but sounds different than normal. Took Solenoids off and cleaned and soaked in line oil. Still not working. Through trial and error, my front tires are down to 8 psi ****. Maybe deflate valve stuck???? Not sure how to take off ANY Guidance is greatly appreciated
Old Mar 9, 2014 | 02:52 PM
Judah0713's Avatar
Default CTIS not working
Took Solenoids apart and cleaned. Took compressor apart and metal rings were at the bottom. Could it just be the piston rings are worn out? Air coming out exhaust when I run the inflate but not filling tires. How do I test solenoids?
Old Apr 18, 2014 | 01:30 PM
Centauro97's Avatar
The H1 shop manual is probably a good starting point:
http://www.4x4us.net/documents/humme...tilisateur.pdf
Old Apr 27, 2014 | 11:13 AM
BusterBrownH1's Avatar
Default CTIS Solution
My solution was to just take it out. I never off road so I got tired of the leaks. I removed the parts at the wheels and put a metal screw in valve in the wheels and now its just like a normal tire...no leaks.
JensH2
Sep 14, 2025 08:52 AM
Evolve13
Sep 7, 2016 02:01 PM
Biff Budd
Jul 30, 2013 06:45 AM
Happy Hummer
Nov 29, 2012 10:05 PM
hmcoleap
Aug 22, 2006 01:14 PM
