coolant level no chang hot/cold
Old May 8, 2015 | 10:00 PM
happythree's Avatar
Default coolant level no chang hot/cold
i lost some coolant a few weeks ago. no other symptoms.
now the level is the same hot or cold?? its just under the seam where it was when i added. i looked in the morn, then after a drive??
ideas?
Old May 11, 2015 | 12:07 AM
whylee's Avatar
Under normal driving, the level will probably stay the same, thats normal. If it was overfilled it could have puked some out. If your temps seem fine I wouldnt worry about it. The level in my Alpha has been the same since I changed out my coolant in November, I have put almost 10,000 miles on since then. Now if it overheats or seems to be running too cold, it could be a thermostat issue.
Old May 11, 2015 | 12:10 PM
happythree's Avatar
it seems there is a hot and cold line, hard to see. i think it goes up hot huh?.
mine stays the same?
Old May 11, 2015 | 02:26 PM
RKSmith163's Avatar
I've noticed very little if any change in the level on mine between hot and cold. Once it dropped about an inch, I refilled and it hasn't happened since. That was over a year ago. Just keep an eye on it and don't worry too much. huh Good Luck
Old May 12, 2015 | 11:19 AM
happythree's Avatar
ok thanks much...
twinmill28
Jan 5, 2012 07:13 PM
Herm
Feb 5, 2008 09:16 AM
sgt940
May 23, 2007 08:46 AM
