coolant level no chang hot/cold
i lost some coolant a few weeks ago. no other symptoms.
now the level is the same hot or cold?? its just under the seam where it was when i added. i looked in the morn, then after a drive??
ideas?
ideas?
Under normal driving, the level will probably stay the same, thats normal. If it was overfilled it could have puked some out. If your temps seem fine I wouldnt worry about it. The level in my Alpha has been the same since I changed out my coolant in November, I have put almost 10,000 miles on since then. Now if it overheats or seems to be running too cold, it could be a thermostat issue.
I've noticed very little if any change in the level on mine between hot and cold. Once it dropped about an inch, I refilled and it hasn't happened since. That was over a year ago. Just keep an eye on it and don't worry too much. huh Good Luck
Herm
Feb 5, 2008 09:16 AM
