Clicking Noise from Wheels??
Old Jun 25, 2011 | 09:12 AM
  #31
PDAisAok's Avatar
Is there a fix for this? I never had this issue when I first got it about a year ago and now it sounds terrible.
Old Jun 26, 2011 | 03:00 PM
  #32
Lee's Avatar
Lee
Default click click
Little bid of silicone between thumb and fore finger and apply to edge of center cap so it looks like a small o-ring then let it dry for hours then re-apply center caps . happyness ( tustin hummer referal )
Old Oct 9, 2011 | 11:49 PM
  #33
sk.vlado's Avatar
Default noise solution
take the metal sleves from the bushings between the body and frame out ...clean them from dirt and grease them and put back....no more noise
Old Apr 4, 2012 | 04:33 AM
  #34
Kylie's Avatar
I was wondering if you found a solution to this problem as I too have this noise and no one seems to know what's causing it
Old Apr 4, 2012 | 04:45 AM
  #35
Kylie's Avatar
I'm referring to the clicking noise in the front wheels, like there is rocks in the tyres but there isn't. Big sad face, noise is driving me nuts
Old Apr 8, 2012 | 10:21 PM
  #36
Lee's Avatar
Lee
Default dang clicking
take all the center caps off and drive around , if clicking stops then reinstall with small silicone bead that you let dry completely on the mate surface of the cap , use the gasket maker stuff instead of the sealant so the wont be a bear to remove... also you can throw some talc powder on the dry silicone to keep it from trying to stick to your wheeels any thing is better than driving around with a bad *** hummer that sounds like a kid on a bicycle with cards in his spokes ! good luck let me know if it worked it worked for me !!
Old Apr 7, 2013 | 02:18 AM
  #37
Kylie's Avatar
Default Clicking noise under h3
Ok, so i also have this CLICKING noise!!! VERY annoying! I have had the wheels changed, CV checked, all the front suspension checked and NOTHING... Its doing my head in. Has anyone got any ideas to what it could be?????? It sounds like horses with shoes on are in my Wheels (well maybe its not the wheels) The mechanics have had the wheels off and claim they still can hear it?????
Old Apr 7, 2013 | 07:18 AM
  #38
If you have OEM wheels with center caps there is a 99% chance that is what it is. The wheel flexes slightly and causes the clicking noise at the cap. Possibly a failing half shaft but not likely.
Old May 4, 2013 | 03:30 PM
  #39
gerry's Avatar
check your rotor bolts to see if any backed out
gregaac
Sep 8, 2014 09:04 AM
LikinmyH3
Jun 22, 2012 07:14 AM
Kylie
Apr 3, 2012 10:39 AM
mdwoods
Jul 22, 2006 06:49 PM
ke6itf
Feb 2, 2006 02:55 AM
