H1--ABS modulator, shuttle valve seals, source?
Old May 4, 2013 | 04:17 PM
earlyRover's Avatar
Default H1--ABS modulator, shuttle valve seals, source?
The Hummer I uses an ABS modulator, pump made by WABCO. For you Hummer mechanics, I have a few questions for you regarding that modulator:
Is the modulator also used on the Hummer 2 and/or 3, or only on the I ?
Most importantly, regarding the modulator shuttle valve seals (two very small seals, about 1/4" in diameter---not true " O-rings," but actual seals), where is a source supplier for those two seals, only the seals; nothing else, where can I buy them? Jack
Old May 4, 2013 | 09:15 PM
As far as I know the Wabco modulator shared with RR is only in the H1. None of my trucks are ABS trucks so I haven't had to source those. Check with hummech here on the forum. I know he rebuilds those units semi-regularly.
MT H1
Jan 23, 2023 07:04 AM
jeep60s
Aug 13, 2010 06:39 PM
J_Martin
Apr 13, 2009 09:49 AM
Wrongway1
Apr 13, 2008 12:41 PM
Doc Olds
Sep 1, 2007 02:35 AM
