Cleaning engine 2006 H2
Old Jun 17, 2015 | 10:06 PM
Seventhmoreno's Avatar
Question Cleaning engine 2006 H2
so i took my truck off roading in mud and got the engine full of mud and dirt. I want to clean it this weekend I have a degreaser and a brass and plastic brushes. I want to know what parts I should cover when I rinse it down can any1 please post pictures and or a video.! I have never cleaned it so that's the reason I'm using a degreaser. At the same time I'm going to change out my belt since it has never been changed and is starting to squeak. Any advise will be appreciated. Thanks
Old Jun 18, 2015 | 07:59 AM
calif phil's Avatar
I don't think you really need to cover anything. I would avoid high pressure and use something like Gunk Foamy Engine Cleaner. I would buy a Gates or Goodyear serpentine belt and be sure and check the tensioner and idler pulley once you get the belt off as they can be your source of squeaking.
Old Jun 18, 2015 | 05:31 PM
2wheelmonster's Avatar
I usually started the engine and just sprayed it down with garden hose.
Old Jun 18, 2015 | 10:11 PM
madmayo's Avatar
Be very careful spraying around your intake. My mechanic soaked my motor with a hose and the water got into the knock sensors which are located under the intake. I had to replace my knock sensors, harness and intake gaskets.
The seals are known to fail and the foam under the intake allows it to pool and seap in. I knotched the rear foam and left the front one out so water would exit freely.
Also built dams around sensors to divert water around them.
Just be careful with the water.
Old Jun 21, 2015 | 10:34 PM
Update
Old Jun 21, 2015 | 10:38 PM
Default Before
Before.
Old Jun 21, 2015 | 10:41 PM
Default Final
I covered the alternator. Took off the intake and covered the trottle body the. Scrubbed everything with a plastic brush rinsed it waited till it dried applyed gunk original for about 10 min scrubbed again around the really bad parts and rinnsed really well. I did not use the shine product maybe next time also let the car run for avout 15 min till everything looked dried
Old Jun 21, 2015 | 10:44 PM
Default Final 2
Sorry about the multiple post i cant figure out how to add multiple pics im using my phone
Old Jun 22, 2015 | 01:17 AM
LoJac963's Avatar
Looks good.
I use my gas pressure washer when I wash the rig. I'll put the 40 degree tip on and just hold the wand further away from all the engine components. Takes care of pretty much everything. I'll dry what I can reach with a towel and let everything else air dry. Never had an issue doing it that way.
David Stanley
Nov 5, 2014 03:12 AM
Diablito
Mar 12, 2014 02:21 PM
finall
Mar 13, 2008 02:18 AM
importkiller
Sep 14, 2006 07:53 PM
Autogeek
Aug 6, 2005 03:35 PM
