Cheap MAF sensor?
Old Oct 16, 2018 | 06:44 PM
Hbrezzi's Avatar
Originally Posted by MixManSC
Only way you will be able to determine if it has a non-original tune/flash on the ECM will be to use a higher end tuner like EFI Live, HP Tuners, or a GM Tech2.
One way to check for intake leaks is to remove the upper beauty cover from the engine, start it up and let it idle, then spray around the edges of the intake, throttle body, injectors, fuel pressure regulator, PCV tube, etc and if the idle changes in a spot, there is a leak. Do this when the engine is cold and do NOT get any spray on the exhaust manifold. You can use a can of carb cleaner or even a propane torch (NOT lit obviously I hope). Do this outside and good idea to have a fire extinguisher handy. A fire is unlikely but better to be safe.
These mention what I'm talkign about. I've done it a dozen times myself....
https://www.jalopyjournal.com/forum/...sting.1032664/
One of the issues on our engines (and all GM LS engines) with the plastic intake manifold is the intake manifold gaskets can harden and deform causing small intake leaks.
I have finally tried but no changes in idle occurred. I will leave the car sometimes next week with my local mechanic who assures me he will fix the issue. We'll see...
I will keep you posted.
Thanks!
egroegart
Aug 18, 2020 08:25 AM
Raffi76
26
Feb 18, 2015 03:20 PM
JRAguilar
Oct 13, 2013 06:58 PM
HummerH2
Mar 20, 2011 03:00 PM
jumperdp
Nov 19, 2008 02:56 PM
