Charcoal Canister Testing P0455 :(
Old Jul 6, 2019 | 10:10 PM
legerwn's Avatar
I have 2 android phone based scanners, Torque and OBDlink, let me go fire them up and see which one has the tank pressure.
Old Jul 6, 2019 | 10:40 PM
legerwn's Avatar
In my 08 H2 I used Torque Pro to log the Evap Pressure when I was diagnosing my P0455 issue so I know it will work for the 08 model
Neal
Old Jul 7, 2019 | 04:21 PM
clsimmon's Avatar
Does anyone know if you can read the tank pressure with a Tech2?
Old Jul 7, 2019 | 06:41 PM
legerwn's Avatar
Yes, the Tech2 will allow you to view and manipulate the solenoids and pressure
You have full control of the system with a Tech2
Old Jul 8, 2019 | 11:42 AM
VehiGAZ's Avatar
Hi! I'm chasing P0446 myself and have to find the vapor canister to check the solenoid valve.
Can someone point me to where I can find the canister?
Old Jul 8, 2019 | 02:59 PM
legerwn's Avatar
On the 08 & 09 its tucked up under the drivers side between the frame rail and the body
Old Jul 8, 2019 | 04:33 PM
VehiGAZ's Avatar
Thank you legerwn!
Turns out I was really looking for the canister vent solenoid, which is mounted up above the gas tank behind the left rear wheel. I removed it and bench tested it and it made clicking noises on 12V, so I reinstalled it.
The next part to check is the purge valve in the engine bay.
Other than OBDII code P0466, I started having trouble when filling the tank... it will only take a gallon or so before the pump starts shutting off, which suggests that something isn't opening to collect or vent the vapor pressure in the tank.
Are any of these parts known to fail more often than others? It's a 2008 H2 with ~130k miles on it.
Old Jul 8, 2019 | 10:02 PM
legerwn's Avatar
The vent solenoid has a filter on the inlet which will plug and can cause the issue of slow filling also the canister can get clogged and will cause the same issue.
When you had the vent solenoid off did you take the filter out and clean it?
Old Jul 9, 2019 | 07:28 AM
VehiGAZ's Avatar
I did not see a filter on the solenoid inlet. I am inclined to just replace the solenoid if I have to go in again.
Btw, I did a couple of short (<10 mile) drives after toying with it all and while I did not get another CEL yet, I did still have problems filling the tank, so clearly my problem is not solved.
I can get a new GM canister from Amazon for $90 delivered so I will replace that and the solenoid. Should I replace the valve in the engine bay as well?
Old Jul 10, 2019 | 04:18 AM
legerwn's Avatar
For the slow fill issue I would start with the canister and vent solenoid.
My canister was packed solid, no rattle when i took it off, i blew it out and knocked it around a bit untilnthe carbon was loose again then re-installed it and my slow fill issue got a lot better. I also cleaned the filter in the vent solenoid.
The filter is inside the solenoid, there are some small clips around the top of the solenoid you need to pull them up and pop the top off to find the filter.
Replacing both is the best option
myrddin
May 2, 2025 10:11 AM
H2Miami
Apr 10, 2024 10:41 AM
tharber
Feb 10, 2016 03:06 AM
parabat
May 27, 2011 12:21 AM
dscaberboy
Nov 19, 2008 03:25 AM
