Changing tire size on my H3......
Old Jun 19, 2009 | 08:08 AM
FloridaFeMan's Avatar
Default Changing tire size on my H3......
I am considering changing my tires on my H3. Currently riding stock P265/75R16 tires. If I go up to P285/75R16, do I need to recalibrate my speedometer? If so, how does one accomplish this? Is it a big expense to do this?
Old Jun 19, 2009 | 12:35 PM
bflank's Avatar
As I understand it you need to reprogram your PCM. The dealership can do it of course, but so can others like pcmforless.com. I'd call them.
Old Jun 19, 2009 | 02:20 PM
Right on! The PCM needs to be programmed to calibrate the speedo.
Old Jun 19, 2009 | 10:12 PM
CREEPINGONCHROME's Avatar
I just use my gps!
Old Jun 20, 2009 | 09:15 AM
TINKED's Avatar
I went from the 285 to the 315 and its off exactly by 5 miles. So if I am going 60 I am really going 65. We GPS it !
Old Jun 25, 2009 | 03:50 PM
abacusah's Avatar
Hey Tinked, did you raise the front end to get the 315 to fit or you don't need to?
Old Jun 25, 2009 | 08:14 PM
oruna1's Avatar
I just went from 285's to the new Goodyear MT-R with kevkar tires in the 315-75/16 size. I raised the truck 1" but had them mounted prior to raising the truck. I didn't have to raise it I just wanted a little extra ground clearance in the front.
Old Jun 25, 2009 | 10:29 PM
Blue_Demon's Avatar
Hmm thats weird i have 265's on my 2006 h3 ans was told if i went to 285's i would need to raise the front is this true..i was told it would cause rubbing in the front?? have i been dooped into buying smaller tires?!?!
Old Jun 25, 2009 | 10:59 PM
NJTEX's Avatar
You were 100% Duped. On the bright side, 265's likely give you the best value, on-road performance and fuel economy.
I'm in for a new set of tires this weekend and I'm still going back and forth between 265's and 285's.
Old Jun 26, 2009 | 11:37 AM
Wrongway1's Avatar
Wink
I was told that I could not run 315's on factory rims. Is that true??
