Cant engage 4 wheel low
Old Mar 27, 2018 | 03:14 PM
osuna_669's Avatar
Default Cant engage 4 wheel low
I have a 2006 h3 hummer , and for some reason I can't put it in 4 wheel low, it'll go into 4 wheel high but not low, any recommendations on what it could be ? .... my h3 is a 5 speed manual if that helps ,
Old Mar 27, 2018 | 05:39 PM
RKSmith163's Avatar
Is your Gearshift in neutral and are you moving 3-5 MPH?
Old Mar 27, 2018 | 07:39 PM
osuna_669's Avatar
i am in neutral but i am at a stand still. should i be moving a tiny bit?
Old Mar 28, 2018 | 06:57 AM
Try it while moving 1-5mph. If that does not work you may need a new shift fork.
It is a known issue. The stock one in 06 was plastic. They make a metal replacement.
Old Mar 28, 2018 | 06:54 PM
osuna_669's Avatar
ok so i tried moving a tiny bit but no luck , maybe i do need a shift fork , i noticed it after my abs light came on , think it has anything to do with that?
Old Mar 29, 2018 | 10:09 AM
ABS light on? Ahhh...
You can not shift in or out of 4lo with an ABS fault. Something in the BCM/PCM will not allow it.
Fix the ABS fault and you will probably be able to shift into and out of 4lo.
Old Mar 29, 2018 | 07:43 PM
osuna_669's Avatar
i cant shift into 4 wheel lo. i will get that checked out thanks !
Old Mar 30, 2018 | 10:18 AM
Have the abs code read and replace the offending part.
Post here what the code is.
ReRun0007
Sep 30, 2014 01:26 PM
carolympus
Sep 20, 2013 07:17 AM
Kinder82
Apr 4, 2013 08:30 PM
papacoinsauto
Dec 16, 2010 09:10 PM
mrhaney
Apr 16, 2006 10:46 PM
