Cam shaft potions sensor problem
Old Aug 23, 2017 | 12:28 PM
Ericlee33's Avatar
Default Cam shaft potions sensor problem
Swapped out both position sensors and changed oil check engine light still comes on and after checking with code reader still says it the cam shaft positions sensor
Old Aug 23, 2017 | 02:05 PM
Welcome to HF.
We might be able to help you if:
1) You bothered to indicate year and model with miles on the clock;
2) what the actual code/code were that are being thrown; and,
3) posted this in the correct forum.
I can help you with number 3 above if you would like to provide the additional information.
Old Aug 23, 2017 | 02:57 PM
Ericlee33's Avatar
2006 hummer h3
Code is p0014
Old Aug 23, 2017 | 09:39 PM
sycraft's Avatar
there is an oil control valve for the cam that is probably bad
Old Aug 23, 2017 | 10:45 PM
Ericlee33's Avatar
The engine seems to come on when I go on a long drive like 2hr plus
Old Aug 23, 2017 | 10:46 PM
Ericlee33's Avatar
Check engine light
Old Aug 24, 2017 | 09:13 AM
Originally Posted by Ericlee33
2006 hummer h3
Code is p0014
Miles?
Old Aug 24, 2017 | 02:18 PM
Ericlee33's Avatar
Old Aug 24, 2017 | 02:42 PM
Known problem with many Atlas motors, more likely with high miles. The Camshaft Actuator Solenoid screens get crudy, dirty, goobered up, and or may even fall out,
Images courtesy of Hummerz from an old post.
C31322
Sep 11, 2013 03:27 PM
bigstick0000
Nov 28, 2012 10:06 PM
Kimmea
Aug 1, 2012 07:47 PM
Widespread Hummer
Oct 24, 2010 08:26 AM
cknorr28
Jul 2, 2008 01:50 PM
