A/C Shraeder Valve replacement question
Old Sep 10, 2014 | 05:12 PM
jsbihn's Avatar
Default A/C Shraeder Valve replacement question
Hey all,
I just replaced the shraeder vale on my 03 H2 on the low side (smaller valve), and when I went to replace the shraeder valve on the high side (larger valve) i noticed there was no valve there.
What was in the port look like a small ballon at the bottom being held in place i guess by a ledge. It seems valve like in that I guess I could push in and it would rebound out.
Does this sound right?
Or is there something there on purpose and I need to just push it down and install the valve
I have had A/C issues from day one of this truck, and I am wondering if it is because the low side valve leaked and the high side valve is not even there?
Help?
Old Sep 13, 2014 | 12:08 PM
jsbihn's Avatar
Well thanks to HumTech over at Elcova Hummer forums, I got my answer.
I appreciate it and think that he is definitely a guru plus
For those that might be wonder, the answer was that the high side is a ball spring setup. It has a ball that is perched on a spring that pushes the ball up to seal it (and presses down to release)
I also found out that this valve is NOT serviceable, which makes sense since it basically a ball and spring.
Thanks again HumTech (even though I know he cant see it on here)
Old Sep 16, 2014 | 08:59 PM
2004H2's Avatar
The High side is replaceable,it actually splits,you need a pair of vise grips and a shop towel/rag,grab the upper side of the high side with the vise grips and slowly turn counter clock-wise to remove the spring ball assby....the new replacement is Avalable at NAPA...cost about 16$,ask them for assistance,as mine explained it to me.......Hummer service told me there was only a full line replacement,it was unservicable......by a customer........wrong.....lol......
Old Sep 17, 2014 | 06:02 PM
jsbihn's Avatar
Good to know that there are parts out there , even though the manuals say there arent
egroegart
Dec 30, 2021 08:56 AM
Hummphrey
Aug 5, 2015 03:57 PM
jsbihn
Apr 26, 2014 02:56 PM
xroperx
Head and Valve Problems.
170
Apr 13, 2009 07:46 PM
btstyx
97
Aug 2, 2007 09:34 PM
