Brake Question
Old Oct 7, 2014 | 10:39 AM
ChadB's Avatar
Default Brake Question
Hey guys. I'm having some issues with the brakes on my 2007 H3. It doesn't seem like a brake pad thing. The previous owner added slotted discs which squeaked a bit so it's tough to know for sure. So I wanted to ask your opinions.
When I press the pedal I never know what I'm going to get. Sometimes it's solid, sometimes it has a little travel before they engage and sometimes it's a lot of travel. I can always "pump them up" to solid though. There is plenty of fluid in the reservoir.
A possible related/unrelated thing is a have recently gotten the check engine light on. It popped on and one time said fuel cap in the display. I reset the light but a few days later it returned. I read that is usually an emissions thing though.
I can easily change brake pads but beyond that I don't have the equipment or space. If you have replaced the pads on your Hummer were the symptoms similar or does it sound like a different issue? My experience is when brake pads are bad they are always bad every time you press the pedal so I'm thinking something else. My unprofessional opinion is that there is air in the lines but I'm not sure and don't want to attempt bleeding them myself.
NOTE: Just noticed that perhaps this should be moved to the H3 section. Sorry about that.
Old Oct 7, 2014 | 11:33 AM
I would not use slotted cross drilled rotors on an H3 unless it is purely a road queen. They chew up pads too, and if you get uneven wear, your symptoms fit to a certain extent. When its time to do brakes, IMHO return to the tried and true AC Delco pads and rotors.
Your "fuel Cap" and any CEL (P0442 & P0455) have nothing to do with brakes. See this other thread for that. https://www.hummerforums.com/forum/h...42-code-33936/
Old Oct 7, 2014 | 12:20 PM
rsc's Avatar
rsc
I'm betting you have air in the system somewhere.
Old Oct 7, 2014 | 01:40 PM
ChadB's Avatar
Yeah, I think air too. It's a little freaky in traffic to press the pedal and have so much travel, especially with something so heavy.
Old Oct 7, 2014 | 04:51 PM
Raise vehicle, with wheels off the ground, and check for brake drag, common problem if brakes are overheating. Also check for loose wheel bearings while wheels are off the ground. GL
Bornabe
Aug 20, 2011 08:28 PM
Manitoba H2
Apr 26, 2011 12:09 PM
ador
Sep 22, 2010 12:16 PM
Browns1
May 20, 2008 10:37 AM
dwaxman1
22
Mar 29, 2008 05:26 AM
