Bose Interface
Old Oct 19, 2010 | 07:57 PM
BowTieGuy's Avatar
Default Bose Interface
I just bought my 05 H2 a couple weeks ago and the cd player icon is flashing at me and the player wont load cds. The paint is also rubbed off the buttons so I want to replace it with an aftermarket unit. I dont know what I need to buy so that my Bose will work with it. The CD player has a built in 6 disk changer.
I also have onstar but i dont care if it works or not. I acutally want to remove it and put my dvd player for the headrests in its spot. Can I just unplug my onstar without running into any problems? Thanks for the help
Old Oct 20, 2010 | 06:53 PM
Draketh's Avatar
You're best bet is going to be to get an aftermarket wiring harness. I just did a swap on my H3 and used the Axxess by Metra with great results. Using the aftermarket harness will make it a ton easier to replace the head unit, and also make sure you keep your door chimes, onstar, bose system, etc.
To figure out what adapter you need I would figure out which head unit you want, and then go to a website like crutchfield, select your vehicle, then the head unit, and it will tell you what installation gear you're going to need to get the job done right.
Old Oct 22, 2010 | 10:52 AM
drtom's Avatar
Banned
Default h3 onstar kill
i first pulled the power plug and lost bluetooth which i wanted, so i pulled on* ant and killed it with blue ok, i left power on
u can unplug and toss it from what i see
Old Oct 23, 2010 | 09:22 PM
BowTieGuy's Avatar
I just bought the interface deal and a new head unit the other day so i should be set. Can I unplug and toss the onstar now?
mrigor
Jul 9, 2013 11:08 PM
crank
Jun 19, 2010 07:18 AM
SublimeHummer
19
Feb 3, 2009 11:51 AM
RedRocker
May 3, 2007 07:19 PM
jm4490
Dec 19, 2006 04:52 PM
