Bleeding/burping coolant system
Old 02-12-2015, 10:22 AM
rsm688's Avatar
Default Bleeding/burping coolant system
Well I am going to be replacing my thermostat and coolant temp sensor this weekend, I was searching and can't find a good answer about how to bleed/burp the coolant system on the H3 to get the air out after I swap them.
Also, could I just remove the old thermostat quickly and throw the new one on quick while its leaking fluid out to keep from draining the whole system and filling it with air?
Thanks,
Spencer
Old 02-12-2015, 10:47 AM
No need to worry about air in the cooling system of your H3, irrelevant.
Sure you can pull off the old Tstat and quickly put on the new one, just were a swim mask and snorkel.
Seriously, you pull off the lower radiator hose (you should have a round nose radiator pliers to make it super easy) and drain it into a bucket. Then do the Tstat with a couple towels handy. Then refill with Dexcool. You will need about 1.5+ gallons of coolant (red Dex only) to refill so either buy 2 Gal. 50/50 mixed, or 1 Gal. and mix in distilled water for your 50/50.
This is a good write up: https://sites.google.com/site/happyh...ts-replacement
For more visuals on the radiator drain process, look at this efan related thread where I posted some details. https://www.hummerforums.com/forum/h...version-32647/
Old 02-12-2015, 11:39 AM
rsm688's Avatar
Thanks a ton Doc Olds, you always seem to know the answer to everything I need help with. I greatly appreciate it.
Spencer
Old 02-12-2015, 01:29 PM
Just trying to help when I can.
Old 02-12-2015, 02:44 PM
Bunger's Avatar
I've changed a T-stat and let me tell you, there is no way to do it quickly enough that you wouldn't drain the whole system.
Do it the way that Doc said.
Old 02-12-2015, 03:41 PM
rsc's Avatar
rsc
rsc is offline
I'm sitting here grinning thinking of the results of someone trying to be faster than the radiator fluid.
Old 02-14-2015, 12:55 AM
Raffi76's Avatar
Thanks,
Spencer
Just replaced my thermostat yesterday and trust me there is no way to do it quickly, just getting the screws of the thermostat out is a trick of its own, then getting the hose out..... don't even mention screwing the thermostat back on...... you will end up with coolant all over the place no matter how hard you try. Besides, its probably a good idea to get fresh coolant in there while you are at it.
Old 02-14-2015, 08:23 AM
rsc's Avatar
rsc
rsc is offline
If you had an inline thermostat at the top of the radiator like I do you could change out the thermostat for a different temp without draining all the fluid.
Old 02-15-2015, 02:57 PM
Bunger's Avatar
When the time comes to do my tstat, that's exactly what I'll be doing.
gera8712
06-13-2013 12:31 PM
Bearcat
01-15-2012 09:49 PM
HummerGuyCMH
08-14-2010 03:57 AM
junjun
08-08-2009 11:41 PM
Quick Reply: Bleeding/burping coolant system
