bi-xenon install help
Old Sep 22, 2011 | 10:44 AM
mrigor's Avatar
Default bi-xenon install help
I bought a kit on ebay bi-xenon h13 9008 kit. It hooks up for easy with no problems, but high beams do not work (they glow but the bulb dont move in). The bulbs are have to move in for high beam, and say out for low beam.
You use on ONE headlight plug as a trigger, and the other is not used. If I plug a bulb into the 2nd plug the lights go into high beam mode right away and do not snap out.
You have 3 wires that are used as trigger, maybe they need to be different polarities, or in a different order.
Did anyone install bi-xenon kit on a H3 hummer that can help me solve this problem.
Old Sep 22, 2011 | 10:53 AM
drtom's Avatar
Banned
Default its on u tube
Old Sep 22, 2011 | 11:08 AM
mrigor's Avatar
install is easy, how come my high beams dont work. its all plug and play, maybe hummer h3 has a different wiring setup then other cars on the h13 9008 plug
Old Sep 22, 2011 | 12:03 PM
wfturner's Avatar
Did you do a search ?
Others have had that problem
Hummer Forums - Enthusiast Forum for Hummer Owners - Search Results
HID Kits off ebay, don't expect everything you hear
Old Sep 22, 2011 | 12:38 PM
mrigor's Avatar
Yes, non of the posts have a solution, just problems.
Old Sep 23, 2011 | 10:54 AM
mrigor's Avatar
update: i tried to switch the 3 wires at the plug around, used 6 different combinations. nothing changes at all, no matter how i plug in the wires there is no difference.
Old Sep 23, 2011 | 11:55 AM
drtom's Avatar
Banned
i tried brite white, didnt make much difference,got fogs involved, better, brite whites didnt last long. back to stock
learned to love stock +fogs
Old Oct 1, 2011 | 09:07 PM
maxxx486's Avatar
I installed some HIDs with the high beams. Mine required a battery harness for extra power... I would look into getting some from www.sharphid.com. I went with them as they were a better quality and had a lifetime warranty. Also, I had alot of questions and they were quick to respond and explain to me everything I needed to know. Hope this help :-)
Here is the link to the battery harness only - I would double check to see if it will work with your ballast. HID Battery Wiring Harness
Dennis C
Apr 5, 2007 03:32 PM
altrestle
Jan 4, 2007 07:29 PM
altrestle
Dec 31, 2006 11:11 PM
altrestle
Dec 31, 2006 02:51 PM
bradj89
Nov 22, 2006 05:20 PM
