Axle seal leaking
Old Feb 10, 2013 | 05:12 PM
Nmocean's Avatar
Default Axle seal leaking
I found the drivers side front axle seal leaking on Friday, by Sat it was much worse so I replaced it this morning. It wasn't that bad of a job first time doing it only took me about an 1.5 start to finish, I got the new seal at NAPA they had them in stock part number 15691 $12.03 for the seal. From what I have read, I guess it is common they go bad, so I bought a spare.
Old Feb 10, 2013 | 06:34 PM
Broken Halo's Avatar
Just had mine done under warranty. If you only replaced the seal, you may being doing another replacement sooner than you'd think. Dealership also replaced the axle and said this is a common problem. The axle develops rust and or grooves, and this is what causes seal failure.
Old Feb 10, 2013 | 07:24 PM
BlueH3's Avatar
How do you guys see these leaks...does it reach the garage floor? I'm not always looking under at the front end when its 20F out
Old Feb 10, 2013 | 07:42 PM
Nmocean's Avatar
I saw it first on garage floor then looked underneath that side and saw it. I saw the axle and cleaned it the best I could with scotch brite pad on my high speed bur grinder, then I used some emery paper to clean it up better. I was thinking the same thing, when I put it back together.
motley1987
Jan 10, 2022 01:08 AM
kakash
Mar 25, 2013 05:22 PM
afatouraee
Nov 9, 2012 06:43 AM
BDK
Jan 6, 2012 02:29 PM
CruisinCarAudio
Jul 27, 2006 10:32 PM
