Another starting issue
Old Aug 28, 2007 | 11:56 AM
Herm's Avatar
Default Another starting issue
I thought I had this resolved, anyway after replacing the glow plug as I stated in my last post I was using this vehicle with no problems...I have not started it in about 2 weeks... went to start it yesterday and it just cranks no start with some white smoke coming out in the back??? any takers.??
Old Aug 28, 2007 | 12:12 PM
hmcoleap's Avatar
Default RE: Another starting issue
Do you hear your lift pump running when you turn the key to the ON position?
Old Aug 29, 2007 | 05:56 AM
Herm's Avatar
I swapped out the lift pump a month ago...its working fine...It did start yesterday, it took about 8 to 10 cranks of the motor...
Old Aug 29, 2007 | 08:01 AM
hmcoleap's Avatar
Make sure the lift pump is running anyways... I've seen a new lift pump fail in the first 2 weeks before (defect) -- make sure it is running, even if it is a relatively new part.
Or, it could be "turned off" for some other reason (e.g. faulty oil pressure sender)
Ryan Scott Serrano
Jan 25, 2015 11:09 PM
Happy Hummer
Aug 9, 2014 11:11 PM
baltogun831
Dec 16, 2012 11:11 PM
cricket
Mar 13, 2008 03:14 PM
BlackTiger
Nov 19, 2006 01:32 PM
