Another AC problem!
Old Jun 10, 2016 | 01:21 AM
NFS's Avatar
NFS
Exclamation Another AC problem!
Hello, I am new to hummer, I have a 2007 Hummer H3, and I noticed today that when i turn the air conditioning on, the car idle harder and shakes. not normal! what can cause this problem? also i hear like cranking sound from the front passenger side on idle as well, and when i give it a little gas it goes away and then it come back on idle, and most likely this happen when the AC is on.. what this might be??
thanks a lot
Old Jun 10, 2016 | 09:48 AM
thanks a lot
That is the AC Compressor running, and contrary to your belief, that is normal for an I5.
Same thing happens when the Alternator responds to a heavy load and has to boost output to demand. You are detecting the load put on the belt when the AC Clutch kicks in.
Old Jun 10, 2016 | 11:48 AM
NFS's Avatar
NFS
Oh so that shake is normal? What about he clicking noise that coming from the front passenger side?? Is that normal too ?
Old Jun 13, 2016 | 10:28 AM
Open the hood, start the motor with the AC off. Have a friend turn on the AC after a couple minute warm up and watch & listen to what happens.
Old Jun 13, 2016 | 01:40 PM
NFS's Avatar
NFS
So what I should be looking for when I am doing that?
Old Jun 14, 2016 | 09:54 AM
650Hawk's Avatar
You're looking/listening for the clicking. It is likely the A/C kicking on & off. Your freon could be a bit low, so the A/C will click off at idle, back on as RPMs increase.
Old Jun 14, 2016 | 07:48 PM
NFS's Avatar
NFS
ok i will check tomorrow since its crazy raining today
Old Jun 15, 2016 | 05:26 PM
NFS's Avatar
NFS
i found out that there was something lose was hitting on the intake box and causing this noise. thanks for all u guys help
h3andme
Feb 22, 2011 07:08 PM
bigtbasser
Jan 14, 2011 09:14 AM
dilo2001gt
Jan 7, 2006 03:50 AM
efrainl956
Jul 2, 2005 04:05 AM
