Alpha Posessed Windshield Wipers
Old Mar 4, 2010 | 08:16 PM
itgoes211's Avatar
Default Alpha Posessed Windshield Wipers
OK for starters I am not crazy. About 3 weeks ago I was driving down the road and out of the blue after driving about 15 minutes my wipers decided to make one single pass across my window. I figured it was just a fluke and laughed it off. Well about 3 days ago the same thing happened. Has anyone else had this happen?
Old Mar 4, 2010 | 08:19 PM
Bayrat's Avatar
Did on my S10 and it was the electronic control unit or whatever they called it.
Old Mar 4, 2010 | 08:59 PM
drtom's Avatar
Banned
Default intermittent wipers
this could be connected.
my pontiac trans sport had intmt wiper operation.
i got a junkyard motor assm,,same thing.
the electronics is in the motor assm and the pins for the connector are soldered into the circuit board. the pins flex and crack the THIN solder on the board. i resoldered with lots of solder, all pins on both and its been solid since.
if the motor is pulled to check, UNHOOK the batt cause if you barely move the shaft the motor may try to rotate once and mangle your hand,,,experience!!
im just guessin
tom
Old Mar 4, 2010 | 09:59 PM
H3DwnShiftin's Avatar
Yes!!! My H3 has done that three times over the past year. I took it to the Hummer dealership and they couldn't find the problem. I guess that I'm going to have to deal with it...
Old Dec 23, 2010 | 09:48 PM
wiseguy_75's Avatar
My H3 does this every once and a while...
Old Dec 24, 2010 | 08:32 AM
Dino's Avatar
Happens every once in a while. Can not find any common reason why it does. Dealership is stumped.
Has anyone successfully fixed this issue?
Old Dec 24, 2010 | 09:39 AM
f5fstop's Avatar
The wiper control module, under the grill has been known to get water into it causing some strange problems. Was a big problem with early H3s. I had the problem with an 06 and replaced the module and it went away. My 08 has never displayed this problem. The supplier was supposed to fix the manufacturing problem and it SHOULD have been fixed for 07 and later. But I do say SHOULD.
Old Dec 29, 2010 | 06:35 PM
Lolson's Avatar
I am having this problem currently (just started today!) with my 05 H2. Front wipers wouldn't turn off while the motor was running then, as an added bonus, the rear wiper and washer started going at full speed and wouldn't stop until I turned off the hummer. There is another thread on here dealing with this issue just search wipers. It gives good advice.
dunndw
Aug 22, 2012 09:05 PM
rlmoralez
Sep 7, 2010 09:27 PM
fable123
Nov 28, 2007 06:54 PM
Robja
Oct 30, 2007 02:09 PM
HummerGuy
Feb 15, 2007 04:11 PM
