Aftermath maintenance
Old Aug 19, 2007 | 10:17 PM
JeepeaterH3's Avatar
Default Aftermath maintenance
After an offroad trip, what do you suggest for re oiling and maintaining the suspension components and all critical parts of my truck? im in florida, and i tend to encounter alot of water and mud. what should i do, where and how? lol. Thanks!
Old Aug 20, 2007 | 02:27 PM
Default RE: Aftermath maintenance
Trip to the spray wash ought to do. I would not lubricate anything other than a grease fitting, and there really ain't none of them under there. You put oil, grease, lube on stuff and it collects dirt, which then creates problems. Good cleaning and that is all I recommend. Check the front axle shaft rubber boots for tears or damage, check for leaks, an address anything you find. Check the manual for lubrication points and see what's up.
Old Aug 20, 2007 | 09:57 PM
Drainbamaged's Avatar
Make sure your front lower control arm bolts are tight at the frame. I didn't maintain mine and the bolts actually wore out the hole in the frame and i had to get the holesrewelded. Also check your rear lower control arms at the frame for loose bolts. Those seem to be a problem also on my truck at least but i push the truck pretty hard when i am wheeling it.
Old Sep 29, 2007 | 08:32 PM
hilljob26's Avatar
i like that first pic,thats a nice shot
tavion2378
Dec 17, 2007 09:43 PM
doorgunner
May 25, 2007 02:32 PM
TigerLily
22
Mar 1, 2007 02:03 PM
Gunner_45
Feb 5, 2007 12:59 AM
CarlosC
Nov 1, 2006 12:58 PM
