Aftermarket brakes???
Old Feb 22, 2010 | 07:54 PM
achinaghost52's Avatar
Default Aftermarket brakes???
i recently found out that the 05 h2 comes with 12.8 inch brakes up front and 13" ones in the back. i find this absolutely appalling. my mothers x5 comes standard with 16" and its alm0st 1500lbs lighter than the h2.
so, i have begun the search for aftermarket brake rotors and pads. i know that brembo makes a good system (but its 5k, way out of my range). so, when i take my truck in to have it straight piped (from the cat back of course) i am going to ask about brakes lol.
what are your guys's thoughts on the brakes?
Old Feb 23, 2010 | 02:26 PM
BIGT2148's Avatar
my brakes have personally been fine. Never had a problem out of the two H2's I have.
If you want to get Brembo's then great! With my trucks, I do not need them. The brakes have been good enough for me but thats just me.
Maybe some other people will chime in that trailer heavy.
Theres one guy out there that has H2 Limos that may have to fight brake problems.
Old Feb 23, 2010 | 05:38 PM
VegasGuy's Avatar
An X5 is a not an off-roader. You can get away with low profile tires and large rims that allow for larger brake discs on an X5. On an H2 you need a lot of rubber between a rock and a rim to keep from destroying it. They are two different kind of animals.
I don't have any issues with my brakes. They work pretty well.
Old Feb 25, 2010 | 12:06 PM
VegasGuy's Avatar
I only want to add that the guys who have put large rims on their Hummer should seriously consider upgrading their brakes to larger diameter discs. I'm no expert, but those who know say you need additional braking power to control the kinetic energy inherent in large rotating rims due to all that metal being further from the center axis.
Old Feb 25, 2010 | 09:47 PM
no, im staying with the stock 17's on mine, but i drive bmw's alot. so im used to stopping on a dime basically (my mothers x5 and 750li) and i just find i have to work to get my beast to stop. idk, im not saying they are bad, but lots of people on here talk about getting more power, but you gotta remember to upgrade you brakes too i guess, and if you have 17 rims on these trucks and the 315 wide tires or whatever, you can surely put some 14" brakes or something slightly bigger than the 12's in there
Old Feb 25, 2010 | 10:14 PM
pteam's Avatar
yes you could. just be prepared to spend several thousands...
Old Feb 26, 2010 | 09:11 PM
ive seen the brembo kits for 5k, so im pretty sure i can find something modest for about 2.
MeBelovinMyH3
Nov 3, 2012 08:58 AM
sconnoll
Jan 15, 2007 11:30 PM
Dennis
Nov 26, 2006 12:28 AM
fisherman119
Oct 3, 2006 06:56 PM
Rayvyn
Nov 25, 2005 07:09 AM
