AC not working right
Old Jul 21, 2011 | 06:18 PM
accely's Avatar
Default AC not working right
Hi everyone. I bought a 2005 H2 Black a few months ago. I tested the AC when I bough it and it was working perfect. Recently when I've tried it I've noticed it is barely blowing, almost feels like nothing, I can however feel the cold air. Also, you can hear a "tap" noise on the passenger side every 3 seconds or so while the A/C is on, soon as you turn off the AC the noise will stop.
Any ideas? I ran the issue by a guy at a local auto shop and he said it might be the blower or some other part that "opens up" when you turn on the ac/heat. He also mentioned it's a cheap part ~10$ but it'd take 10 hours to take apart the dash (labor would be through the roof)
Old Jul 25, 2011 | 08:04 PM
busa944's Avatar
Sounds like your actuator switch may be broke. It controls the flap that adjust from defrost, vent and floor, if you here a popping noise the little plastic controller on the actuator may be broke. See if it blows out of the floor or defrost harder than it does the vents. I have changed them on other GMC vechicals hundred of times.
Old Jul 25, 2011 | 08:13 PM
Muddydawg75's Avatar
He's not BSing you.... the removal instructions are 14 pages in the service manual.
Old Jul 25, 2011 | 08:16 PM
busa944's Avatar
Yeah its not a fun job!!
Old Jul 26, 2011 | 09:28 AM
accely's Avatar
thanks for replies, here's an update..
tried it again today and it came on full blast and cold.
However, if I lower the fan speed below the top 2 notches then the fans stop blowing. Very odd... I wonder if it's some kind of issue with the climate control unit itself
Old Jul 26, 2011 | 02:50 PM
Do you have your climate control in auto or manual?
Old Jul 27, 2011 | 08:53 AM
accely's Avatar
it starts in Auto which is what gets it up to high. I believe once i start moving the fan speed down that it switches to manual. It keeps working if I keep the fan speed all the way up
JensH2
Sep 14, 2025 08:52 AM
TxHummer07
Mar 22, 2015 11:02 AM
maxwellmark
Jan 16, 2013 08:10 AM
Nxsov180db
Apr 17, 2008 04:51 AM
importkiller
32
Mar 9, 2007 07:50 PM
