AC Compressor Help!
Old Jun 10, 2014 | 02:54 PM
omarluna2's Avatar
Default AC Compressor Help!
Hello everyone,
I need some help. The past day or two I noticed that My AC was coming in and out. it would be cold for a few seconds then it would go back to normal temperature air. it does this over and over. When I opened the hood. I noticed that the A/C compressor turns on and off. What I mean is that the A/C clutch kicks on and then it kicks off. I think I need to replace the compressor out. Have you guys dealt with this issue?
Old Jun 10, 2014 | 06:23 PM
Reineke's Avatar
It could be low, which means you have a small leak. There is a low pressure and high pressure interlock in the system to keep it from hurting itself. Take it to a shop where they will evacuate the system, leak check it, and add the correct amount of freon back in. All for ~ $50-75.
I learned the lesson the hard way, but you really don't want to add your own freon without a pressure gauge and do not add leak stop. Those will just cause more issues down the road.
Daryl M
Jun 20, 2012 02:44 PM
Monarchy
Oct 22, 2009 12:00 AM
extralims
Apr 27, 2009 12:51 PM
hmcoleap
Aug 22, 2006 01:14 PM
shortbus
Nov 3, 2005 08:36 PM
