95 5.7l tbi hard start/ no start when hot
Old Feb 29, 2012 | 11:21 AM
marsstar102's Avatar
Default 95 5.7l tbi hard start/ no start when hot
I recently put in a performance cam and now that the engine is back together it will start and run when the engine is cold. when it is cold it cranks for a while before firing. once it is up to operating temp it looses power and stalls out and wont start again with out starting fluid. If i spray a little starting fluid it starts. i replaced the fuel pump, fuel filter, fuel pump relay, ignition coil and the distributor. when doing the cam i installed new plugs and wires and dist cap and rotor. pls help.
Old Feb 29, 2012 | 05:23 PM
joenuzz's Avatar
Could be a timing issue. I rebuilt a small dirt bike once that was doing the same thing after I put it back together. I ended up having the can gear off by one tooth
Old Feb 29, 2012 | 06:14 PM
I'll check the timing then thanks.
H3ummer
Aug 21, 2023 09:51 AM
281hummer
Jun 14, 2010 09:49 AM
J95H1
Oct 29, 2008 11:55 AM
