7-Wire Trailer Wiring question
Old May 23, 2008 | 10:30 PM
H3Dude812's Avatar
Default RE: 7-Wire Trailer Wiring question
I would assume that withthe factory7 pin, every pin is hooked up, correct? I need the back up light for my boat trailer brake disconnect.
Old May 23, 2008 | 11:33 PM
canuckh3's Avatar
lepack...I checked with my dealer and they couldn't find a part number for a harness, so...I ended up creating my own with split-loom and I tie-wrapped it along side the factory harness that follows along the drivers side frame. It's no big deal, I added 2 wires - the blue trailer brake circuit and a 12V hot all the time circuit for trailer interior lights etc. Like I said, I didn't bother with reverse lights, its in the factory harness and I suppoe it would be easy to tap into ... I believe from what read here and there, it's a light green wire.
h3 dude, I would assume that the factory 7-wire would be wired to the standard config. Easy to compare your H3 socket to your trailer wiring with a cheap test light type probe, assuming you know how the trailer is wired.
Old May 25, 2008 | 10:34 PM
lepack's Avatar
Thanks canukh3, that makes sense.
One more question. I went hunting for the blue brake wire that dead-ends in a connector behind the battery as you suggest. Is this it?
[IMG]local://upfiles/3385/D5DAE479BA744D66B48B503BD4F8422E.jpg[/IMG]
Old May 26, 2008 | 02:13 PM
canuckh3's Avatar
Yes it is...to confirm, there should be a light green wire on top of it at the connector point. From there, I cut the blue flush with the connector and used a good butt splice into my harness. If you didn't want to go that extreme you could fish that wire out and use one of these;
http://www.tessco.com/products/displ...mp;eventPage=1
Old May 26, 2008 | 11:32 PM
lepack's Avatar
Thanks for you help!
thermalfrost
Mar 12, 2014 01:50 AM
Brent Whitfield
Feb 12, 2014 06:40 PM
2007H3
Apr 18, 2012 02:12 AM
jasontag
Apr 26, 2010 10:08 AM
SeaGar
17
Apr 3, 2007 03:40 PM
