2008 H3 Adventure, 3.7L, Trans Oil Pan
Old Jan 25, 2012 | 11:52 AM
gallf1's Avatar
Default 2008 H3 Adventure, 3.7L, Trans Oil Pan
Hi:
I want to buy an OEM Automatic Transmission Oil Pan so that I can have a drain bung welded in for future oil changes. Does anyone have a part # or source?
Thx
Old Jan 25, 2012 | 11:57 AM
B&M Drain Plug Kit.
About $7.00
http://ecx.images-amazon.com/images/...500_AA300_.jpg
Napa makes one as well.
Old Jan 25, 2012 | 12:04 PM
gallf1's Avatar
Thx...I saw that when I searched the forum....concerned it is going to leak or somehow get loose....
Old Jan 25, 2012 | 12:19 PM
If you are concerned about leaks, pair it with a 1/2" stat-o-seal, you even have room for one top and one bottom if you want to go crazy (they are sold in pairs). Earl's Performance 178008ERL - Earl's Performance Stat-O-Seals - Overview - SummitRacing.com
These are quality, better than the old school copper washers, no need for O ring grove. We've used them on some race cars, no leaks ever.
I used a B&M drain plug kit right out of the box on an old truck, over 150K miles, never leaked, never loosened up?
Old Jan 25, 2012 | 07:45 PM
thedave8's Avatar
only bummer is there is the depth of the thickness of the nut inside the pan of fluid that wont drain out.....maybe depth of 3/8 inch? but gets most out....put it in corner of pan and park at an angle to drain....
Old Jan 26, 2012 | 10:35 AM
It's not really that bad. Is a welded on bung better, sure.
The reason for a drain plug is to remove the pan without spill the crap everywhere so you can change the filter and then put the pan back on to re-fill with fresh. You can also flush by draining, refill with fresh, drive some miles, then drain again and change the filter. One trick is to put the plug back in after it has drained before you remove the pan, then pour out that little bit still in the bottom of the pan.
Nobody just drains an AT to refill without changing the filter, and how many times do you change AT fluid?
A trans Pan (ACDelco #24240206) is $33.00 + shipping [priced higher & w/ Tx at the local dealer] and has no drain plug. Not everybody has the time or resources to weld in a bung themselves, or go have it done, so IMHO an $8.00 plug kit is a no brainer.
Old Jan 26, 2012 | 09:42 PM
thedave8's Avatar
sure they do....my 2500 chevy pickup has factory drain plug, and it is nice to swap new fluid in between filter changes....clean fluid works wonders...you are more likely to do it when its easier than engine oil change.....different strokes............
Old Jan 27, 2012 | 08:34 AM
OK, maybe you got me there.....
Nobody changes their oil without a new oil filter?
Old Jan 27, 2012 | 07:41 PM
thedave8's Avatar
right you are!!! Oil filters are a bit easier to change..
We do have a nutty customer at work, though, that insists we change his oil filter only....LOL, he insists to change oil every other filter change!
synthetic oil, but still......
hmer
Apr 26, 2017 12:08 PM
wpduffey
Jun 20, 2015 02:15 AM
hmer
Jan 20, 2015 07:17 AM
ragtop73
Jan 23, 2011 10:49 AM
Broken Halo
Mar 7, 2010 08:02 PM
