2007 H3- Luxury Alarm Issue- Beep on going into Reverse
Old Apr 5, 2018 | 04:19 PM
Catdaddy's Avatar
Default 2007 H3- Luxury Alarm Issue- Beep on going into Reverse
Hi all, did not find any specific info in the manual or from a search.
As stated, 2007 H3- Luxury model, NO idea what Alarm it is. My issue is every so often after I disarm and start the truck when I put my truck in reverse I hear a slight car horn beep right when it goes in reverse, just one quick beep. Its not the longer beep you hear to tell you the alarm had gone off, this just happens when I put the car in reverse. If I put the car back into park, then reverse again it will do the beep again. Note that I do not have any type of backup system, I do have Onstar but no backup mirror or system.
Any idea, anyone have a link for info on the alarm that came with it stock? I've changed the alarm key battery, check all connections, I'm going to see if any codes come up after I get the device for it. It happens maybe once a week, just concerned.
Old Apr 5, 2018 | 04:27 PM
Broken Halo's Avatar
Guessing you bought your 3 used? More then likely the previous owner installed some sort of module for a back up alert.
Old Apr 5, 2018 | 05:06 PM
Catdaddy's Avatar
Hi, thanks for responding. Yes used, I had it for about 2 years now, this issue just started about 2 weeks ago.
Old Jun 1, 2018 | 05:42 PM
Catdaddy's Avatar
Hi, just wanted to see if anyone has any other ideas for this issue. The alarm was randomly beeping then going off, sometimes the locks would engage then un-engage when I try to lock it. I was driving the other day and I noticed when I tap the steering wheel the alarm dings and the doors locks all open then close again. It must be a short, I had them rework the ignition key before (year ago) as it was defective, any ideas what this may be?
edit- On a side note, if I have to manually lock the truck how on earth do I lock the back hatch, don't see anything related in google except with the power lock issues?
Ty.
Old Jun 3, 2018 | 07:55 AM
BruceS's Avatar
Not much help but I would suggest downloading wiring diagram for door locking system and start tracing wires. If all is good then it is probably in bcm.
Old Jun 4, 2018 | 04:16 AM
Remove any and all aftermarket alarm and related component from your vehicle first. This will include any backup/reverse alarm.
Old Jun 4, 2018 | 08:35 AM
Your issue is aftermarket alarm related, not an H3 problem. Good luck.
fnfal308
Jan 20, 2016 08:48 AM
H2008
Feb 24, 2015 11:33 AM
Gomer
Apr 19, 2013 06:43 PM
uurxin1
Oct 16, 2010 03:07 AM
Negativecreep0
Jun 24, 2008 02:44 PM
