2003 H2: Where is the rear hatch sensor?
Old Mar 14, 2015 | 08:03 PM
Rob R's Avatar
Default 2003 H2: Where is the rear hatch sensor?
My '03 has been, largely speaking, fine after buying it used a couple years ago. Today, my (factory) alarm has gone off twice in the driveway. After unlocking the H2 to silence the alarm, when I try to lock it for a second time to get the "honk", it won't.
I checked it out, and the dash says "Rear Access Open". However, the hatch is closed and nothing is blocking it. I closed it a couple of times, it went away, I was able to fully lock/alarm it, but then the alarm went off again a little while later.
Where is the sensor/button/etc. that the H2 uses to determine whether the hatch is closed or not? I've verified that it fully locks/unlocks, it just doesn't seem to sense that it is closed.
Old Mar 14, 2015 | 09:04 PM
Synthetickiller's Avatar
I'm just guessing here, but isn't the sensor inside of the door where the metal hook clicks into place?
I don't recall a pyscial tab sticking out on the trim around the door, so I guess you'll have to go inside of the hatch & replace the sensor.
Old Mar 16, 2015 | 08:13 AM
calif phil's Avatar
It's built into the latch. I know on some Ford trucks they have a similar problems and spraying WD40 into the latch will make then work correctly again. Might be worth a try.
DZLROKET
Jan 25, 2023 06:37 PM
VBUTCHER
Apr 10, 2011 09:53 PM
Zack'sH2
Jan 14, 2011 04:05 PM
red92901
Jun 20, 2010 06:07 PM
solarflare
Jun 25, 2008 10:25 PM
