06 h3 3.5 p 0171 low rpms oil light buzzer
Old Jan 25, 2012 | 01:01 PM
lilblkshp's Avatar
Default 06 h3 3.5 p 0171 low rpms oil light buzzer
new oil sensor, verified oil pressure. goes away when rpms increase so i believe thats due to the low rpms. smoked engine and found various vacuum leaks and fixed all. same issue, give it a lil gas and let off and the engine wants to die and does sometimes? any help please
Old Jan 25, 2012 | 02:46 PM
Miles, and did you recently make any other changes or mods?
P0171 is almost always a dirty MAF so start with getting some MAF cleaner and follow the instructions on the can, next vacuum leak downstream from the MAF... but you say you fixed those. Last and least is fuel pump issues, check for low pressure.
The false stalling is almost always from a dirty TB. Clean that (if you have 50k miles or more).
There have been 287,642 threads on this, a search can help.
Just scroll through the recent H3 board, its all been hashed.
Welcome to the forums.
Old Jan 26, 2012 | 01:00 PM
lilblkshp's Avatar
Default thanks
turned out that the big box inbetween air filter and throttle body was leaking all around the seal. and the low idle was the app sensor, replaced and like new. thanks for the help
Old Jan 26, 2012 | 01:36 PM
What's an app sensor?
Old Jan 26, 2012 | 01:45 PM
lcurle's Avatar
Congress......*rimshot*
Old Jan 28, 2012 | 11:31 AM
lilblkshp's Avatar
ACCELERATOR PEDAL POSITION SENSOR, the new electronic throttle by wire systems have them
JRAguilar
Oct 13, 2013 06:58 PM
Kinder82
Apr 4, 2013 08:30 PM
drtom
Jan 17, 2011 09:23 PM
hummer07
Nov 18, 2008 10:46 AM
HingHum
Mar 20, 2007 06:18 PM
