03 H2 Rear Hatch Problems
Old Nov 20, 2010 | 05:38 PM
rosco111's Avatar
Default 03 H2 Rear Hatch Problems
We have a 2003 H2 that has been stretched into a limo. Unfortunatley the rear hatch handle is broken, however we can remove the handle completeley and tug on the cable that should release the hatch but this doesn't work. It acts like it is locked even though we have tried every unlock button and all remotes. Unfortunatley there is a permanent partition inside the vehicle blocking access to the inside of the hatch. HELP! We really need to get this open, is there a way from outside after removing the rear access panel that I can manually unlock???
Old Nov 21, 2010 | 09:19 AM
Lakeside Restorations.com's Avatar
Off the top of my head those already would be the ways to do it, or try getting in from the outside anyway..
Hopefully tho you will think of something else before it comes to:
Old Nov 21, 2010 | 11:08 AM
olfart's Avatar
read is another thread somewhere on here where the owner banged on the hatch around the edges while applying pressure to the handle...in your case the cable....and the hatch opened. Seems that the retracting bolts around the outside of the hatch stick...especially if it hasn't been opened in a while. Might be worht a try and if it works be sure to lube the bolts before closing the hatch again.
________
PORNSTARS NIRVANA
Old Nov 24, 2010 | 09:12 PM
TheLimoGuy's Avatar
^^^ THIS.
It sounds silly but it should work. And like he said, once you get in lube it good before closing it. The other thing I recommend is opening it each time you wash it. That's often enough to keep it working smoothly.
Scooter_911
Jul 30, 2022 08:35 AM
VBUTCHER
Apr 10, 2011 09:53 PM
red92901
Jun 20, 2010 06:07 PM
Raffi76
Jan 26, 2009 03:25 PM
solarflare
Jun 25, 2008 10:25 PM
