Cranks but no start,fuel pump intermittant...
Old Oct 25, 2025 | 03:33 PM
factfive's Avatar
Default Cranks but no start,fuel pump intermittant...
2010 H3 t 3.7.109k .Battery died installed fresh replacement.Turn key sometimes fuel pump will run,other tims turn key no pump humm.Noticed gear indicator on dash shows park as normal,but as soon as i turn key jumps to 3 on dash ..turn back to park goes to P.So changed the ignition switch and the same issue persists,Cranks,intermittant fuel pump,no start,turn key indicator jumps to 3.Did the passkey relearn several times to no avail.Is this a possible PCM issue? Truck never had any issue whatsoever starting and ran great before battery died.Never had a passlock issue as well.i scanned it got PO230 failure of primary fuel pump circut. Like i said pump comes on intermitantly..
Old Oct 25, 2025 | 05:42 PM
Sam!'s Avatar
Sound like the notorious cheap GM battery terminals worn and unable to properly tighten on the battery post, causes some of the issues you are describing. i would start there by replacing them if they have not been. yet.
Old Oct 26, 2025 | 07:20 AM
factfive's Avatar
They are the original terminals,
Old Oct 28, 2025 | 04:16 PM
650Hawk's Avatar
Cut them off and replace them immediately. Well known issue, and the first thing that EVERY H3 owner should do. These trucks are notoriously finicky about even slight variations in voltage.
Mitch Haun
Apr 5, 2025 06:22 PM
Cryptoyeets
Apr 13, 2024 08:53 PM
Stripp13
Jul 19, 2019 06:51 AM
kevinocon86
Feb 13, 2015 12:44 AM
Humveeforce
Feb 1, 2015 03:13 PM
