Body lift + Leveling
Old Dec 6, 2020 | 11:17 AM
SamG's Avatar
Default Body lift + Leveling
Hi guys,
I have a question, it has probably already been discussed, but I searched and not found a clear answer.
I leveled my H3T using the T-bar crank technique. I put extended bumpstops and bilstein longer shocks. I took mesurements and I'm set at 23.5" as discussed here many times by members, BUT i would need an additional 1.0" to 1.5" to have my wheels able to clear my fenders at full turn.
if I go with a outfitter design H3T body lift kit, will I mess with some steering components and geometry, or a body lift is a different process than will not affect this...? It's my first truck, I'm learning a lot right now!
thank you guys! You are all so useful!
Old Dec 6, 2020 | 02:37 PM
wpage's Avatar
Consider either changing your tires...
Or cut or change out fenders.
Old Dec 6, 2020 | 02:45 PM
H3Luxembourg's Avatar
dude what tires /wheels do you put on? You don't need a body lift after cranking your T bars Put 1.5 or 2" longer shackles at the rear leafs and that's it. You must do an alignment after cranking the T bars !!! for me, i removed the front Sway bar. Excellent off road , more flexing on front now and no rubbing at the front bar just a little slower in round abouts now ​​​​​​​ ​​​​​​​ ​​​​​​​​​​​​​​
Old Dec 7, 2020 | 11:24 AM
Sam,
It all depends on the width and offset of your wheels and the tire size.
Please post that information.
I have run 37s on OEM wheels with a 1" body lift.
Old Dec 7, 2020 | 01:04 PM
atvspeed4's Avatar
Same here, almost all of our H3s run 37s on OEM wheels with just a bodylift.
Old Dec 9, 2020 | 08:45 AM
gpcalero's Avatar
Originally Posted by SamG
Hi guys,
Body lift will lift... the body. It'll help some but like Tainter said, it really depends on the wheel specs.
Old Dec 9, 2020 | 02:17 PM
Who ever selected your Rimz, did not know what they were doing. 35s fit all day on stock wheels.
Old Dec 10, 2020 | 12:34 PM
Looks like SamG looked in to HF today, but never responded to any of our questions.
  • Last Activity: Today 12:32 AM 12.10.2020
2009h3t
Dec 19, 2018 03:16 PM
Amanda Sheppard
Aug 25, 2017 03:25 PM
Anthony Chiarello
Aug 24, 2014 10:25 AM
bird72763
Dec 6, 2011 04:50 PM
Indy
Feb 24, 2011 11:38 AM
