Yaw sensor?
Old Dec 17, 2020 | 06:46 PM
Workinman's Avatar
Are you still using the Crappy Azzed OEM Battery Terminal Connectors? If so, hack them off immediately and replace with a quality aftermarket set like Stingers or your favorite brand. The OEM Battery Terminal Connectors are worse than crap, and those alone can cause all kinds of electrical Gremlins, just like the separate wet BCM issues.
I am still trying to figure out why you tacked on this thread. Your friend's H3 is doing "these things" is what? Your issues have zero to do with the Yaw Sensor, but I guess that is OK as neither did the OP's. ??????????
Ok I tacked on to this thread to possible learn something as the hummer I was involved with had traction control , and several other lights on the dash on. Could not get the shifter to move . Stab control was off . . I appreciate your suggestion of replacing the cables . I watched Paul Danner Scanner Danner a instructor at a tech collage trouble shoot a H3 for a problem and it turned out to be poor connection in the fuse box. Spent a few hours watching him trouble shoot different problems not that that matters here either . I just posted to possible help the fellow out . The cables I appreciate the advice . Thanks
Old Dec 18, 2020 | 10:39 AM
Not the cables, just the Battery Terminal Connectors.
[IMG/]
Old Dec 18, 2020 | 06:20 PM
Workinman's Avatar
Thumbs up
[IMG/]
Thanks I appreciate your time
Doctor Umarov
Oct 26, 2020 08:57 PM
Rashid Iqbal
Jun 2, 2020 11:16 PM
Sarge1
Hummer H3T
Jul 29, 2019 12:55 PM
Desert Dan
Apr 22, 2008 05:31 PM
