Weather stripping next fix….
Old Dec 30, 2022 | 03:07 PM
Numb's Avatar
Default Weather stripping next fix….
So on too the next fix. I have purchased new GM weather stripping that runs the length of the front and back doors. The stripping goes on top of both doors. And I have also purchased new GM weather stripping that goes around the body where the door seals. My question about installing this is should I use a weather stripping adhesive or install it dry? Thoughts please?
Old Dec 30, 2022 | 04:38 PM
zenith's Avatar
Install them dry. They have a metal pinching built in to the rubber which enables them to fasten to the body very tight. If you use adhesive, good luck cleaning that crap off if you ever need to remove the weather stripping.
Old Dec 30, 2022 | 05:20 PM
Numb's Avatar
Good thought on getting them off if I ever need too.
Old Dec 31, 2022 | 08:17 AM
calif phil's Avatar
What are the part numbers you purchased, are they still available from GM?
Old Dec 31, 2022 | 09:31 AM
Numb's Avatar
https://www.gmpartsdirect.com/v-2004...and-components
Parts numbers
25868657
25868658
Tom Richards
Feb 14, 2017 06:24 PM
RAHF
Nov 11, 2014 09:07 AM
Xlr8n
Jun 20, 2012 03:24 PM
Dawg19
Jul 27, 2006 01:31 PM
