water pooling in passenger floorboard
Old Nov 15, 2010 | 07:25 PM
cuzzndon's Avatar
Smile
Unscrew the sun visors and let them hang. Peel back the rubber trim molding around the sunroof opening (it's not glued, just press fit). Pop the little cover off each 'A' pillar that says 'Air Bag', using a small flat blade screwdriver. Remove the screw under it, and wiggle out the trim piece. You'll then be able to gently pull down the front portion of the headliner. Don't worry, you can't set off the airbags by bumping or disturbing them. They need an electrical signal to fire the pyrotechnics.
Halo, thanks for the assistance. It worked. No more water.
Old Jun 23, 2011 | 10:41 AM
girlzh3's Avatar
Default water leaking onto passenger floor board...
HI!
I have an '08 H3 Alpha and have had this problem for several months now... I took it to car repair shop and they couldn't get water to leak. However, if bad weather comes with alot of rain the water just poors in! I've read this entire thread but still not sure how to access the drain tubes. Can someone please help with further details??? Thanks!
Old Jul 18, 2024 | 01:07 PM
Cheyenne Nichole's Avatar
Default Leaky sunroof
Originally Posted by trevortcaruso
turns out the windshield had a spot at the bottom that wasn't siliconed very well. i got it fixed but now i am preparing myself for what appears to be an inevitable sunroof leak. my truck is garaged so i hope mine doesn't leak for some time. has anyone figured out how to prevent the sunroof leak from happening?
Drill out the gromets on both drain lines. I cleaned them before, they just get logged again.
BundyDonaldson
Dec 15, 2020 12:42 PM
Propst72
May 5, 2016 05:08 PM
1sBtrThnN0ne
Sep 5, 2012 08:29 PM
Razzledazzlecam
Jan 5, 2012 09:09 PM
Autumn Walker
Mar 25, 2010 10:40 PM
