Vibration in gear shift
Old Sep 9, 2020 | 04:19 AM
Flow's Avatar
Default Vibration in gear shift
2008 h3 hummer. Has a problem when shifting gears (its a manual). When it get to 2000rpm, when depressing the clutch and change gears the gear stick severely vibrates and makes loud rattling noise. Vibration and noise only occurs when shifting gears up or down. Have changed out the uni joints, all engine mounts are in good order, all the pulleys, air-conditioning, water pump pulleys are aye ok, nothing sticky or binding in that area. Anyone got any suggestions or experienced this problem?
Old Sep 9, 2020 | 09:14 AM
gpcalero's Avatar
Sounds like your throw out bearing might be going bad. Especially if it makes the noise when the clutch is depressed, then goes away after reengaging the clutch.
Old Sep 9, 2020 | 10:02 AM
How many miles on it?
Old Sep 9, 2020 | 03:07 PM
Flow's Avatar
Originally Posted by doc olds
how many miles on it?
90270
Old Sep 9, 2020 | 03:08 PM
Flow's Avatar
thanks ill check it out
Old Sep 9, 2020 | 08:24 PM
Post the vin number.
Old Sep 9, 2020 | 09:29 PM
Flow's Avatar
checked the clutch and not the throw out bearing and not the spigot bearing in the back of the engine which locates the transmission shaft either. Still stuck if anyone has any other ideas
ProphetPVD
Jan 11, 2017 03:45 PM
willdoesstuff
Nov 17, 2013 07:14 AM
Sess113
Feb 16, 2013 12:10 AM
billystric
Aug 25, 2010 08:41 PM
HummerGuy
18
May 5, 2007 02:27 AM
