Undercarriage Rust Issues
Old Feb 19, 2024 | 12:42 PM
amanmustafa's Avatar
Unhappy Undercarriage Rust Issues
My 2007 Hummer H3 was in UpState NY for 11 years and the rust is killing me! I need to replace the fuel pump but my Florida mechanics are worried about breaking the fule line or the fuel-tank belt or may be even the rusted frame. They are not sure if the parts are available, and cannot estimate the cost - all just to replace the fuel pump! Any advice will be much appreciated.
Old Feb 19, 2024 | 01:14 PM
If your frame is that close to falling apart, you are driving a death trap.
Fuel lines can be made, even if they were not available. The tank straps are available cheap from many sources.
When a repair shop responds to your request for service as you describe, why would you bother? They are obviously whiners and do not want to work on your old rusted truck.
Go someplace else that actually has skilled techs on staff ready to work.
I also MOVED this to the H3 section as it tells everybody NOT to post anything in the H3 FAQ sub-section.
Old Feb 21, 2024 | 03:50 PM
wpage's Avatar
There are some good anti rust rattle can products available. Rust Oleum for one that help with oxidation problems.
When you live in the snowy areas, where salt and sodium chloride are used to melt ice. Rust will be a problem. In these areas where salt and other rust promoting things are used on roadways. Rinsing the undecarrige and spraying anti rust products is recommended.
Old Apr 6, 2024 | 11:22 AM
NTONIUS's Avatar
I'm in Canada, an hour from the Buffalo NY border.
I bought my H3 in March 2022 and it had a quite a bit of rust.
I have family in Virginia and they own a mechanic shop, we visited summer 2022.
I basically worked and up kept the shop, doing electrical for them wiring up some compressors etc.
in return the scraped off tonnes of surface rust.
Once we finished that we used rust o leum underbody coat. There was a thicker one for main chassis etc. And there is a more oily one we used around the diff bolts etc to enable easy future service. Rust has subsided but we need to re apply yearly before winter because it seems to wear off over time.
Old Apr 6, 2024 | 02:07 PM
wpage's Avatar
Rust-Oleum 248658 Rust Reformer Spray, 10.25 oz, Black
Visit the Rust-Oleum Store Visit the Rust-Oleum Store
4.7 4.7 out of 5 stars
8,371 ratings 8,371 ratings
5K+ bought in past month$8.97$8.97 $0.88 per Ounce($0.88$0.88 / Ounce)
H3manforever
Jul 31, 2024 04:51 PM
Cryptoyeets
Apr 13, 2024 08:53 PM
Hummerh22
Jul 22, 2021 02:25 PM
E-dragon
Feb 4, 2015 05:53 AM
Broken Halo
Nov 9, 2010 10:21 AM
