Transfer case shuddering after oil change- help pls
Old Sep 23, 2019 | 08:01 PM
Originally Posted by Alibou
Just found this:
This comes from prior issue (2006) of GM Techlink service news and it may applicable to current models.
Quote:
This information applies to 2007 and prior GM passenger cars and trucks.
Dexron III is being phased out as a product name. It is being renamed Manual Transmission Fluid and carries p/n 88861800 U.S. (88861801 Canada).
If fluid p/n 88861800 U.S. (88861801 Canada) is not yet available when servicing a manual transmission or transfer case, Dexron III can be used in its place.
DO NOT use Dexron VI in place of manual transmission fluid in any manual transmissions or transfer cases that specify Dexron III, as a failure may result.
Whatever your reading is BS!
Your problem started when you refilled with "Motul"
3- I checked on the net and found ATF Dexron 6 is ok, so I used Motul 100% syn Dexron 6
Get that shiat outta there before you destroy the TC, and REPLACE WITH THE PROPER FLUID!
Old Sep 23, 2019 | 08:19 PM
Alibou's Avatar
I will!!!
But what is the proper fluid??88861800 mt?
I am not in the US 😏
Only choice is Motul dex 3 or dex 6 😭😭
Old Sep 23, 2019 | 08:23 PM
Old Sep 23, 2019 | 08:41 PM
I am posted in Africa: no rockauto or Amazon!
Amazon has been delivering to Africa since 2015?
Old Sep 23, 2019 | 08:54 PM
Alibou's Avatar
Nope
They Got blocked at customs....
What do you think of mobile 1 dex3 100%synthetic?
Since they say if you can't find 88100... use dex3
Old Sep 23, 2019 | 08:55 PM
according to what you and i posted 88861800 is DEX 3 they just changed the name to 88861800 MT fluid so DEX 3 is what you need.
Old Sep 23, 2019 | 08:57 PM
Alibou's Avatar
Many thanks, I guess it's my conclusion too.
What will you prefer mobile 1, Castrol, or motule?
Old Sep 23, 2019 | 08:59 PM
i just used Mobil 1 synthetic as that was what was available locally
Old Sep 23, 2019 | 09:01 PM
Alibou's Avatar
And do you think that 60miles in the city damaged anything, since I immediately stopped when shuddering?
Old Sep 23, 2019 | 09:02 PM
hopefully it was not damaged.
