Trans Whine Question
Old Feb 21, 2022 | 09:05 PM
Magpul's Avatar
Default Trans Whine Question
2007 3.7L Automatic 112k miles.
Trans whine in 1st and 2nd gear. Almost sounds like a power steering pump thats low on fluid.
Whine is tied to the RPMS. The higher the RPMS the louder the whine.
No whine while coasting in any gear. No whine in P, N, 3rd or OD.
Trans fluid is full and is decently clean.
I had an idler pully replaced that was REALLY whining and this whine was masked by that louder sound.
Wish i would have known this "hidden" problem as i just bought the truck.
Any input or sugestions would be appreciated
Thanks!
Old Feb 22, 2022 | 09:27 AM
When was the last time you changed the Trans Fluid and Filter, the Transfer Case fluid, front and rear diff lube? Might as well ask about engine oil too.
Your T Case is more likely to make a whine sound than the Trans.
Old Feb 22, 2022 | 12:09 PM
Magpul's Avatar
Unsure on trans, diffs, and t case fluid changes, just bought the truck. Oil has about 1500 miles on it according to the sticker.
I will look into the t case being the culprit. My (uneducated lol) guess just connected whines in certian gears to be trans related.
Thank you!
Old Feb 22, 2022 | 05:02 PM
NFS
Jan 4, 2021 07:22 PM
ketchikanmd
Oct 18, 2018 01:20 PM
Rjvette23
Aug 15, 2016 12:29 PM
chuffysplace
Nov 17, 2015 06:14 AM
Roy79
Mar 21, 2013 10:52 PM
