Rpm bouncing
Old Nov 29, 2020 | 06:40 PM
NFS's Avatar
NFS
Default Rpm bouncing
Hey guys I have a hummer h3 around 87k miles. When I am driving on the highway let’s say going 80 at the same speed the rpm will be like going from 3 to 2500 back to 3 and like bouncing it happen and been noticing it a lot when I am going fast on high rpm it will be bounce specially if I am in the same speed. I did a research some said might have low trans fluid I did a fluid change and made sure it’s not low but it still does it.. anyone got an idea? I just start noticing it recently
Old Nov 29, 2020 | 08:49 PM
Opposite for a trans, rpms would increase. What gasoline are you using?
Old Nov 29, 2020 | 10:06 PM
NFS's Avatar
NFS
93. Everything I use is the same it just recently started :/ and it doesn’t happen all the time but i notice it more. What might be the cause of it ?
Old Nov 30, 2020 | 10:05 AM
Your Trans is cycling between full lock up (OD) and Third and might be on its way to a rebuild. Did you change trans fluid and filter?
Old Nov 30, 2020 | 05:38 PM
NFS's Avatar
NFS
yes I did. The car runs fine and shift fine it’s just this at certain speed . Not sure why
Old Dec 1, 2020 | 09:33 AM
Does it do the rpm change when the Hwy is flat? Or only when there are some rolling hills?
Old Dec 1, 2020 | 10:42 AM
NFS's Avatar
NFS
I think mostly hills or inclines. I haven’t seen it so much for flat as far as I remember
Old Dec 1, 2020 | 03:18 PM
RPM's would increase on an incline to maintain mph.
Old Dec 1, 2020 | 04:14 PM
NFS's Avatar
NFS
but it increase and decrease back and forth every few secs
Old Dec 1, 2020 | 04:42 PM
You need to clarify, what are your RPM'S cruising @80MPH(OD locks in around 50mph)? 3K or 2.5k?
