Rpm bouncing
Old Dec 1, 2020 | 04:49 PM
NFS's Avatar
NFS
You need to clarify, what are your RPM'S cruising @80MPH(OD locks in around 50mph)? 3K or 2.5k?
let’s say I am going 55mph cruising sometimes it will be bouncing like 3k then 2.5 then 3k and 2.5 at the same speed and same pedal just bouncing, and u can hear it too like the engine get louder then back to normal
Old Dec 1, 2020 | 04:54 PM
@55mph, 25%- throttle, you should not be @3k in OD. Do you have a tuner installed?
Old Dec 1, 2020 | 05:11 PM
NFS's Avatar
NFS
my ecu is tuned by James from Supermodulation
but the car was running fine before it just recently started doing that
Old Dec 1, 2020 | 05:49 PM
I don't diagnose mods! Your original post was driving @80mph(3k about right in OD), however, driving in 3rd @55mph would be around 3k, when OD locks in, RPM'S would drop! If you are locked in OD, and the rpm drops, I would check fuel delivery. Btw, I only shift to D, when I drive on the highway +55mph, a way to prevent premature wear on the transmission, 3-4 shift is between 45-55mph.
Old Dec 1, 2020 | 07:45 PM
NFS's Avatar
NFS
well it’s random sometimes 55 sometimes 80 it’s at random speed . And what u mean shift to d. It’s automatic I have to have it on d to drive
Old Dec 1, 2020 | 08:14 PM
Yes you can shift an automatic transmission, 4 selections:
Old Dec 1, 2020 | 08:57 PM
NFS's Avatar
NFS
Oh interesting but see I didn’t had that problem until recently with the rpm bouncing :/
Old Dec 1, 2020 | 10:11 PM
RU driving like you stole it?
Old Dec 3, 2020 | 01:59 PM
NFS's Avatar
NFS
https://youtu.be/24QMFOv8Opo
lol no sir I baby the crap out of her
Old Dec 3, 2020 | 02:35 PM
Ok, that's not it. Did you scan and check for codes stored? RU using top tier gas?
