Traction control error code on dash after radio install
Old Jan 16, 2024 | 05:20 PM
Originally Posted by Jbrooks99
So the one at this link is all I need to diagnose?
Yes SCAN ALL MODULES & post the codes.
Old Jan 17, 2024 | 11:21 AM
Happy Hummer's Avatar
I can say the scanner HummerZ showing is pretty nice. Because I bought it the day he recommended it. It's a bit finicky and slow but works just fine.
Old Jan 19, 2024 | 04:49 PM
Jbrooks99's Avatar
Default Code from scanner
The only codes detected from the scanner are: u1000 and b2602, u1017 and u1301. Any ideas from here? I did replace the battery terminal connectors already which were crap.
Old Jan 19, 2024 | 07:21 PM
U1017 - Lost Communication With Engine Control Module
U1000 - a generalized issue with the data bus, as well as circuit issues like damaged or poorly-done wiring and connections, or potentially a module that has failed.
Old Jan 22, 2024 | 01:51 PM
Who installed this radio?
The unrelated codes seem to point to whomever did the install F'd up. Seems like the installer was poking around with a test light or meter in the wrong places and has no idea what they are doing and/or connected wires incorrectly!
The new radio installation might have fried a portion of your BCM.
*U1000 Generally, this DTC indicates a faulty control module or circuit. The secondary code helps pinpoint the specific cause. If there are no other active codes, faulty grounds, damaged/corroded wiring or a bad connector contact at the module junction/wiring harness could have triggered the U1000 code. the second code U1017 Lost communication with engine control module (ECM).
*b2602 The BCM stores DTC B2602 in memory. ○ The BCM disables the DRL relay control as long as the fault is present. ○ The BCM disables the DRL relay
*u1301 Voltage supplied to the module is in the normal operating voltage range. The vehicle power mode requires serial data communication to occur. The class 2 serial data circuit is shorted high or low for approximately 3 seconds.
Old Jan 22, 2024 | 02:07 PM
maybe the radio illumination wire that supplies the radio from the factory harness is grounding out and shutting down the module. on aftermarket radios harnesses i think its either orange or orange with a white stripe. another issue can be the radio interface module they installed to retain steering control and chimes is pulling down the network bus.
Old Jan 22, 2024 | 02:35 PM
H3s have no steering radio controls.
Old Jan 23, 2024 | 10:41 AM
thats fine the rest may still apply.
Old Feb 27, 2024 | 11:04 PM
Jbrooks99's Avatar
Default Fixed traction control failure
Ok here was the fix for two issues.
1) the main issue was the bcm brake control module failure. I replaced this as it was causing the code that low brake pressure. Remember I didn’t have an abs failure just traction control.
2) I had replaced 2 led bulbs in the rear backup lights. These where causing an error code.
Old Feb 28, 2024 | 05:06 AM
BLK WLF's Avatar
Well that’s great news.
Just in case I would run a scan again even it doesn’t show any problems.
Never heard of that a simple light bulb can trigger a code error other than the knock off china spy bulbs.
