TPM Probs, NOT sensors.
Old May 4, 2018 | 09:28 PM
  #41
bosscar's Avatar
Has anyone on this site ever dealt with the light not flashing when entering the learn mode? If so, what was done to fix it?
Old May 4, 2018 | 09:36 PM
  #42
bosscar's Avatar
Originally Posted by ChristianAnarchist
It is frustrating and I've come to the conclusion that we will never find out how this system works. After 5 or 6 years my "CHECK TPM" error has not changed in any way. It's still intermittent, it still has nothing to do with the TPS since they have been changed to brand new ones 2 years ago. Had the exact same behavior with the old sensors as the new ones. We don't even know the route of communication between the TPS and the TPM but it seems likely to be piggybacked on the security system. There's not even any information on WHERE the TPM is but it's likely to be nothing more than a subroutine running in the BCM... When I get the "CHECK TPM" message I just hit the button to clear the message and drive on...
There was one thing that I fixed a couple years ago, the module or transceiver or whatever it's called on the ignition switch was defective and constantly locking out the starter for 5 minutes. I read where that needed to be programmed if you changed it, but mine started right up without any programming. That problem has never come back since I changed it. Any chance that the TPMS or some other system might be boggled because I never had it programmed?
Old May 27, 2018 | 08:21 AM
  #43
ChristianAnarchist's Avatar
Since no one has been able to produce any documentation on how this system works it's anybody's guess. Unless someone from GM "leaks" their NSA level secret on how this works I guess we might never know...
Old Jun 1, 2018 | 12:34 PM
  #44
BruceS's Avatar
This may not help the search and debate on how the system works or why OP has an issue but this is what I found.
I recently picked up a real tech2 and while playing with it landed on the tpms settings. I selected the correct load range for the tires I had installed(E) and moved on to other things. The next morning headed to work the tpms went off with low tire about quarter mile from house. Stoped and check air and it was fine. Light went off about ten miles later.
Once arriving at work I hooked up tech2 and made sure I did process right. Going home that night no issues. Next morning the same issue happened. I live in mid-TN so I knew it was hot the night before so it’s not like what happens in fall or winter.
I tried to do the relearn of sensors, which are only year old, and system would not start. Then I remembered that behind the stereo I disconnected the two plugs from the onstar serial box. I went in and plugged them back up. System now allowed me to relearn sensors.
So I thought I had the problem fixed. Next morning same issue. Did some digging and found that my 07 adventure came with load range C type tires. So I changed load range back to C even though tires are E and I have not had issue since. My guess is even though tech2 gives as option the calibration on bcm does not like that setting.
Tech2 has calibrations up to 2013 and bcm is original and probably has not been touched since it was installed.
Hopefully this helps even though it is from a shade tree non-trained person.
Old Jun 5, 2018 | 03:17 PM
  #45
That's the most I've seen on this issue and it's great info. I don't have that kind of scanner so I can't check any of that but perhaps in the future it will help someone. I still would like to find some info on where the radio signal is received from the sensors. I too have the onstar disconnected but I don't think that's how the signal gets through or my problems would not be intermittent (I could be wrong). It would also be great if the "Check TPM" can simply be turned off. Maybe your scanner can do that.
Old Jun 5, 2018 | 08:01 PM
  #46
BruceS's Avatar
Tech2 won’t let you disable tpms. I don’t know how to tune or write code but the tech2 does have ability to program bcm. I’m guessing if you knew what you were doing you could alter the calibration data before programming the bcm.
Old Nov 28, 2020 | 02:10 PM
  #47
Madadder's Avatar
Default same problem here
I'm in the same boat as you, since I bought this vehicle in 2015 it's been the thorn in my side. I get so frustrated dealing with the GM dealer about it too. My warning light will NOT start flashing when entering the TPMS "learn mode", it just stays on steady. The manual says it is suppose to start flashing and "remain flashing" throughout the learning phase. But, since I put in aftermarket sensors back in 2015 when I put on new tires, the dealer keeps wanting my to buy $400 worth of new factory sensors, before they proceed. What does functioning, or non-functioning, or non-existent sensors have to do with the fact that the light on the DIC will not flash when in the learn mode? I guess the dealer is located in the logic free zone.
I don't think GM knows how it works either.....how's that.
IT HAS TO START FLASHING TO BE ABLE TO LEARN THEM AT ALL. Why can't the GM dealer get past that part of this puzzle?
Everyone here has probably had to do this at some point, does everyone here see the light on the dash start to flash when doing the learn sequence? Please let me know what might be the problem. Thanks.
I too have had nothing but grief with the TPMS in my 2006 H3.
Typically it is of the Low Tire Pressure warning display and the light on the dash Illuminating solid.
I've gone through countless new sensors, none have ever solved the issue.
I just put 4 brand new perfectly good sensors in and came home to relearn them myself.
When I get the system ready to relearn, I get the honks that it is ready, but as the poster above notes the DIC light does NOT start to flash, I can go around still and get the honk for airing down my FD, FP, RP, then nothing for the RD tire. Well within the 5 minutes.
I'm thinking now that whatever module or sensor I am pairing these new TPMS sensors to is corrupt.
Where is the base TPM sensor unit located and can it be replaced?
Unsure if related but our door locks are all out of whack and mainly have to be manually locked from the inside, the key and/or fob will only unlock the driver's door. Inside the lock/unlock all button tries to work but won't lock/unlock all the doors completely.
Old Nov 30, 2020 | 10:00 AM
  #48
Please AVOID Digging up OLD Threads, like this 2+ year old dog. READ: Old Threads/'Necro-Bumping'
Your fobs and TPMS both have to link with the BCM. Do you have a sunroof and has the passenger floor carpet been wet? The BCM is located behind the passenger side kick plate and does not like water. You woule have to re-program a replacement BCM.
jman1335
Sep 21, 2020 09:50 AM
Kar4kim
Nov 15, 2016 03:28 PM
backstage69
Apr 21, 2016 03:54 PM
Kar4kim
Jul 31, 2014 06:45 PM
Ghostrider
Nov 25, 2006 01:20 PM
